H.D Channels
finsally
H.D Channels
Hi,we have a Sony Kdl-32Ex503 we cannot access the H.D channels.we recently updated the software version to access sony internet Tv and updated the software to get BBC I player (Pkg4-114Eul-0108)
The store i bought it from reckons it has the HD tuner,and I may have to restore factory setting to access the H.D channels,is this the case?
Don't really want to do that as it was such a faff obtaining installing the update.
Any advice would be welcome.
Cheers Bob
Bravia55HX
if indeed you have re tuned since switchover you will find HD channels from 101 upwards.
finsally
Hi,yes I have retuned the T.V..I can only get channels up to 59.Perhaps I am not doing it correctly.
Thanks for your help
Cheers Bob
