How do I activate my Sony Bravia on my Homestream console?
puddstrec
I have recently installed Homestream software on my pc, uploaded photos and films on the Library tab. However in the Status page is says that the Bravia TV is inactive. Does anyone have any tips to activate it. I am using a USB wreless dongle in my TV.
5 REPLIES 5
Catmambo
It should normally appear automatically without you having to activate anything which suggests that the TV can't see the PC at the moment for some reason. Which TV do you have and are you running the latest firmware? Does this also happen if you connect using Ethernet cable too?
I have the same problem if someone can please help me, homestream works just for for a moment when i reinstall it.
Catmambo
Shouldn't need activating - just works normally. Have you tried updating Java on your comptuter? We have a nnew version of Homestream going live this week hopefully so this may also help.
thanks
Bernie-the-Bolt
Hard wired may be the solution; see if there is anything useful here (for 'Serviio' read 'Homestream'!);https://www.sony.co.uk/discussions/message/714067
Thalamus.
Champion
Hi all,
just a heads up to let you know that it looks like Homestream V2 is available to download -
Download for Windows
Download for Mac
:thumbsup:
