Remote turn TV on/off in every touch
Remote of my TV, KLD-46EX723 has went crazy by itself.
It worked just normally but now it turns TV on or off in every touch.
I can touch any button and it shuts down the TV and touching any other button it goes back on.
I have had TV unplugged a while but it did not work.
Also I have removed batteries from remote but did not help either.
If I use TV on its own buttons on side, it works just fine, Changes channes, volume etc...
Anyone has any idea about problem?
gofrost
You've not got an option to use any key on the remote to turn tv on or off ? if not this sounds like the remote has failed have you another one that you could use to replicate the issue,if it still does this then maybe an issue with sensor on tv
