How to reset Recommendations list?
veljkoz1
I have KDL-40EX720 Sony Bravia.
In the menu you can turn on the "Recommendations" (Home -> Settings -> System Settings -> General Set-up-> Recommendation -> On/Off). On the home menu, it's represented by a star icon, and lists some most-viewed channels (I guess).
The list is stale and lists some channels I'd rather not see anymore. Is there any way I can reset this list? (without doing a factory reset, which would probably work but then I'd have to setup my tv all over again).
Thanks,
Veljko
profile.country.da_DK.title
Nielsen
I don't think that is possible without factory reset.
For me this feature is total un-useful and I have never seen any good suggestions in the list. It is probably some lousy algorithm that supposedly should predict your TV habits in some way.:smileyconfused:
Nielsen
