I have just purchased second hand a Bravia 40w4710 is it possible to purchase a wireless adaptor for this set and if so which one is compatible, any help would be much appreciated
9662ac
I have just purchased second hand a Bravia 40w4710 does anyone know can I purchase a wireless LAN adaptor for this set and if so the compatible model I would need....any help would be much appreciated
5 REPLIES 5
Bravia55HX
you would need the UWA-BR100 sony wireless adaptor as others simply will not work.
9662ac
Thank you very much your help is much appreciated
drhowells
I didn't think the W series TVs supported this wireless adapter?
Can Catmambo or another Mod confirm that the Sony adapter will work on this TV please.
Bravia55HX
sorry, i believe drhowells may be right, this is an early model therefore not able to connect to the internet in this way, sorry about that.
Catmambo
Dr Howells is corrent  - the dongle only works on 2010 devices onwards (HX,EX,LX,NX etc) rather than the previous generation of models ( S,W,X, Z etc).
Instead maybe look at a 2012 Blu-ray player with integrated wifi as it would cost a little bit more than a dongle, but will give you all the connected functionality including video and depending ont he model, DLNA in one box..
