Info banner keeps popping on
gav_c_83
I have a Sony Bravia KD-55XE7073 & when I’m browsing on Netflix the info banner constantly pops on. It also pops on when I change from certain channels on my Sky q box. I have tried different hdmi slots & all get the same result. Anyway that I can stop this from happening?
Mick_D
Moderator
Hi @gav_c_83, welcome to the Community.
The usual way to deactivate this is as follows:
Home > Settings > Channel Settings > Infobar > Off
Hopefully that will do the trick.
Mick
gav_c_83
Hi, thanks Mick_D, when I go to channel set up it doesn't give me the option to edit it. It is greyed out. It won't let me into do anything with it. 65D7D0D6-9B71-4F9C-AD5D-0B57DE9795DA.jpeg
