Installing Amazon app on Sony TV
eddybaby321
I have a Sony KDL-42W805A. Will I be able to install Amazon Prime directly or do I need to get hold of a firestick?
many thanks
5 REPLIES 5
Sean_Mc
Moderator
Hi Eddy,
You can find more details on how to setup Amazon Prime on your TV here.
Hope this helps!
Thanks,
Sean Mc
eddybaby321
Hi, just wondering if there is a way of installing the amazon app on this model without having to buy a firestick?
Ed Senior
Sent from my iPhone
Pascale_F
Moderator
Hi Ed,
Does your TV not have the Amazon app on it already? Double check in Apps. If it has the app and you have an Amazon Prime account, you can just sign in on the app. If you still need to create an Amazon Prime account, follow the instructions here. You don't need a firestick to do any of this.
This info was from the Q&A section of the KDL-42W805A support page.
Let us know how you get on.
Cheers,
Pascale
eddybaby321
Hi Pascale
I can’t find the Amazon app on this TV. I’m wondering if it is not available on this TV? Please can you advise if it is on this TV?
Many thanks
Ed
Ed Senior
Sent from my iPhone
Pascale_F
Moderator
Hi Ed,
I think it's best to contact Sony Support about this here, as the info I found was from the Q&A section of the KDL-42W805A support page, which suggests that the KDL-42W805A should have the Amazon app installed already.
Thanks,
Pascale
