Interactive applications switch on
profile.country.CZ.title
tomulaLib
Is possible to manually switch on the interactive application? In the MENU I must the "interactive application autorun" switched to off because sometimes the TV is automatically switched off. Because that I can not use the interactive applications on our TV. On the TV is two options - switch interactive application on/off and autorun application on/off. So I think that it is possible to run it manually but know not how. I have latest firmware. We have the KDL-40W605B television.
5 REPLIES 5
EdwinaU
Moderator
Hi there,
Hopefully a forum member will be able to help.
Welcome to the community. :slight_smile:
Best wishes,
M
batee5
Specialist
Hi tomulaLib,
Welcome to our community!
the interactive apps availablity depends on the region and broadcasters. Were you able to get interactive apps on your TV before then it stopped or it's the first time you're trying to use this feature?
Regards,
Batee5
tomulaLib
Sorry for my english I not understand to your reply.
Almou_10
Specialist
Hi tomulaLib,
I guess he was asking for more explanation on this. Are you using apps now or not working any more?
Cheers,
Almou_10
tomulaLib
Sorry, I think my question was clear.
You ask me to about something else that I ask the community. Your question is not related with my question.
Overthat I give You the answer. My TV was not connected to internet before to show a fault.
