Ipad and iphone connection to KDL60W605B.
Jasper12
Hi Folks,
New cat on the block.
Why can't I connect my iPad or iPhone to my new tv?
Other smart phone "Samsung" can connect.
Jasper12.
Jasper12
Hi, thanks again for the info. I tried the Imediashare but it couldn't do all the things I wanted like watch catchup stv. I am going to opt for one of those little apple boxes, I am told that will do the trick.
Thanks again for all your help.
Take care
Jasper12.
5 REPLIES 5
Hi there
You should be able to use Wifi Direct.  See the links in the following thread:
http://community.sony.co.uk/t5/televisions/sony-bravia-and-iphone-4s/m-p/1782183
However, if your trying to "mirror" using Airplay, this will no work, see:
http://community.sony.co.uk/t5/how-tos-faqs-tvs-home-cinema/faq-screen-mirroring-miracast-and-apple-...
Jasper12
Thanks for the info.
When I connect the tv with my iPad I lose the connection with the wireless hub and so can't sent the info to the tv.
Cheers.
Hi there
Try using an app called iMediaShare.
https://us.en.kb.sony.com/app/answers/detail/a_id/34421
Im also a bit "blind" on this topic im afraid, as I dont have an iPhone or similar to expertiment with.  But I have heard that iMediaShare is the way to go - probably should have mentioned it in my first reply :slight_smile:
Jasper12
Take care
Jasper12.
Your welcome
Good luck with everything  :slight_smile:
