kdl-40hx853 internet connection 5007 fault
jimco999
no internet connection fault 5007 on tv connection ok on Humax.
etritd
a factory resetting would fix it.
you go home-settings-system settings-general setup and restore factory setting. then do the internet conection again.
etritd
jimco999
Thanks that done the job, internet ok now.
JIM
