KDL-40WD653 can't view BBC1
neil4768
Hello
I have just tuned in my KDL-40WD653 and when I come to view BBC1 it has no signal, it did find the channel as it is listed on the channel list.  The channel is broadcasting as it is on another TV.   Is there anything I can do solve this issue?
Neil
neil4768
Hi I ended up resetting the TV to factory settings and that solved it
Pascale_F
Moderator
Hi Neil,
Is this a new KDL-40WD653 TV?
You could try retuning the channels. Please refer to page 20 of this manual and let us know how you get on.
Thanks,
Pascale
neil4768
Pascale_F
Moderator
Hi Neil,
That's great. Glad it's sorted.
BW,
Pascale
