KDL-42W805A (WEB TV)
george_michael
Hello friends i am new member and i wanna ask something about my new sony smart tv KDL-42W805A.
My question is if i can watch through web tv various shows ,films and series?Iam from Greece and to my effort to see some video i did not have any lack.Did i make something wrong or this is unfortunately out of range for this model?
Hi there
I have just had a look at the site.  They are using an Adobe Flash plugin for their videos.  Which unfortunately will not work via the inbuilt web-browser.  The website is also quite graphic heavy, of which I would guess this is the reason why you get a "not enough memory error".
So basically - it cannot be done.
Sorry to be the bearer of bad news.
Cheers.
4 REPLIES 4
Hi there and Welcome to the Sony Forums
From your description, Im gathering that you are trying to watch videos via a website (web.tv) using the TV's inbuilt web browser?
If that is the case, in most cases it will not work.  Most require a plugin called Flash to be installed (or another plugin) of which you cannot install.
However if the website is coded in HTML5, the videos "should" play within the browser, as your TV supports HTML5.
george_michael
Dear friend thank you for your instant reply.
I am trying to watch the content video from http://www.antenna.gr/webtv/live.
To my effort to watch any containt video when i enter my choise -i think the first time i try this- it was written that there is not enough memory.
Hi there
Cheers.
george_michael
Thank you again for your instant reply and help.i am obliged !
