KDL 43WF6BU won't switch between HDMI inputs.
kgharr
Hi
I have 2 devices connected to the HDMI ports a Sky box on HDMI 1  and a occasionally  a laptop on HDMI 2.
When I select which input I want to watch I see the same signal on both channels so if I am using the laptop and then switch to HDMI 1 input I still see the laptop. Depending on which input I select first I can see the Sky box on both channels. If I have only one input source connected then I can only see the source on the connected input. I have reversed the inputs and changed the cables with out success.
This TV replaces a 40" Bravia which worked fine using the same input sources and cables.
In my original post I had listed the wrong tv model.
4 REPLIES 4
Sean_Mc
Moderator
Hi there,
I think you may need to switch the video input to 'Auto'.  For more details on this, please see here.
Let me know how you get on?
Best wishes,
Sean Mc
kgharr
Hi
Thanks for your reply
I have set all the inputs to auto without success.
Ken
Sean_Mc
Moderator
Hi Ken,
Please send the following thread here which may shed some light on this issue for you.
Best wishes,
Sean Mc
kgharr
Hi
I have solved this now. I was connecting the laptop while the TV was switched on.
If I connect while the TV is off everthing works OK
Ken
