KDL-46NX720 and Skype
coudim
Hi all,
I'm experiencing some wierd problems with skype: when I accept a video call, after 2-3 seconds skype hangs and TV reboots ... This is happening for the last 1-1.5 month, constantly.
I have updated to the latest  available firmware and echo test (soud only ...) works.
Any ideas would be appreciated.
Thanks!
Hi there
Interesting problem here.  The latest firmware was issued 2 months ago (25/06/2013).
The only thing I can suggest, is perform a Factory Reset of your TV, to clear any "stuck" data or settings.
Hope that helps.
coudim
I'll give it a try today, although it worked (for 2-3 weeks) without problems after the upgrade.
Thanks!
coudim
Unfortunately, the factory reset didn't help.
What I noticed, is that if the calling party starts it's video after the call has been initiated,
it works (!?)
It's not really a solution, but it's a workaround for now ...
Anyway ... thanks!
