KDL-32EX43B not responding
UncleZen
My KDL-32EX43B, has recently stopped responding to:
- Input from the remote control
- Input from the buttons
The light on the TV does flash when you press a button on the remote but nothing happens.
If I turn off the TV, then on again, it works perfectly. If I put the TV into standby then switch on, theres no response from the remote (until I switch off/on again)..
I've reset factory defaults.and re-got all the channels, Ive disconnected the wireless usb adaptor, no difference.
Anyone have any thoughts on what this might be?
Also, I tried to upload the software from the built-in PKG4.114EUB-0108 to the latest PKG4.117EUB-0108.
But it wont update. It simply sits there for >15mins saying its doing the update, but never updates itself. Tried 2 different flash drives same results.
farnwomt
I have an identical problem with my KDL-40EX43B that I noticed on Friday when I returned home after having a month away.
Looking at my TV it appears to have updated itself to the latest firmware, namely:
PKG4.117EUB-0108
as released on the 26/08/2013.  I am sure I am not alone in thinking this must be a bug introduced by the new firmware.  The only way I can clear the problem is to unplug the TV from the mains and plug it back in again.
