KDL32BX320 2 WHITE VERTICAL LINES - HELP!
jolou41
I take it my Bravia tv needs repairing but just wanted to know what's gone wrong as only bought it less than two years ago and not chuffed!
Two vertical lines have appeared on the screen, they're white and around 1cm apart and are just off centre, to the right of the screen. They never go and are totally ruining the picture, I take it that it's a fault I'll have to pay for! Arghhh!
Pascale_F
Moderator
Hi there jolou41,
If nobody offers you any technical solutions here, I recommend you contact Sony Support and they will be able to advise you further.
Thanks,
Pascale_F
Pascale_F
Moderator
Hi there jolou41,
Thanks,
Pascale_F
Hi there
This is either a fault with the T-CON board (or connections to it) or a fault in the LCD panel itself.  Either way, its a hardware fault. Suggest you contact an authorised Sony Repair Centre : Here
Cheers.
