KDL32EX523 Compatibility for wireless adapter UWA-BRA100
ephelant
Can anyone confirm if this model is compatible for wireless adapter UWA-BRA100 to link to a network?
Hi there
No other brands of wireless dongles/adapters will work.
However there are a couple of other options.  See this thread for more information:
http://community.sony.co.uk/t5/Televisions/Dongle-to-connect-a-Sony-3D-TV-Model-Number-KDL40HX803U/m...
Hi there
Looking at the TV's specifications (network) - This TV will work with the wireless adapter/dongle.
ephelant
Many thanks I find the guide a little confusing as it doesn't list my tv model number in the instructions.
Would you know if there is a non Sony branded (cheaper) that will work in the same way?
Regards
Hi there
