kdl32w706b faulty image
deonix9
Hello,
After a while from buying TV  I noticed that SD channels are seen exactly as analogic channels.Only the HD it receives normal.
Please advise me what to do, this situation can be resolved only in service or there are other solutions?
I tried factory reset without any effect of image enhancement.
Digital image processor may be defective?
TV initially display a normal image, but after a while
I see no noticeable difference between Analog / digital.Only HD channels are received correctly, but no SD posts.
Now the problem is that I do not know what has failed, software or TV motherboard.
If it is a software problem can be corrected by software updates?
Thank you.
Hi there
Unfortunately I cannot back head-or-tail of what you are saying - might be a language barrier?  Can you please describe your issue a little more clearer - also are you based in the UK or another country?
