KDL40-EX523 Wont work with HDMI Matrix
Cford67
I'm trying to set up this TV as the 2nd display on a 4 in 2 out matrix and it won't provide a stable picutre at 1080p. I am using good quality cables which have been tested with other displays and they work fine.
The sources are BT vision (only upto 1080i which is OK) Sony BDP s370 (won't do 1080p) and an Xbox again only up to 1080i.
This seems to be a problem with the Sony Bluray and the TV, they do work when directly connected but not through the matrix. The problem is the picture flickers between off/green screen and a breif clip of whatever is playing.
As I said the matrix works fine with other displays such as panasonic'/LG and Samsung.
If there is some setting on the TV that will fix this please let me know?
thanks.
0 REPLIES 0
