KDL40W5810
johnnottingham
KDL40W5810
My KDL40W5810 has just started continuously scrolling all digital channels. Nothing wil stop it. If I unplug the set and reconnect it it continues scrolling. Is there a solution or is it an engineer repair problem.
Johnnott
Bravia55HX
have you tried removing the batteries from the remote?, maybe a key has stuck and is causing the problem, i presume you cant even get to the menu at this point to attempt a factory re set.
if all else fails its likely to be an engineers visit.
johnnottingham
Thanks, will try, but having unplugged tv for a couple of hours it is now OK. You are right, I could not get to menu or anything else
Will wait for it to go wrong again. Fortunately I have Sony 5 year guarantee .
