KDL42W7 - Playings files from USB stick - hide file info
Hi, Does anyone know if there's a way to disable/turn off the file info/summary info that comes up at the start of every clip when playing files via a usb stick?  Thanks
Hi there
Unfortunately there is no way to do so.  I understand that it can be annoying if you are playing lots of small files.  The only thing that I can suggest is the info button on the remote control - may remove it from the screen quicker.
Hi there
