keyboard 46kdl905A
ELISE111S
keyboard 46kdl905A
i have just bought this brilliant tv. i took it home, connect it with a wired usb mouse and a wired keyboard. the mouse works but the keyboard does not. from a little research that i did, it seems that there is an issue. is it SO DIFFICULT for a global and enormous brand like SONY to have these kind of problems that can be solved EXTREMELY easily???
hoping that there is going to be a solution from a next firmware update and eventually not regreting for not buying a samsung 46F8000....
PLEASE, DO SOMETHING.
ELISE111S
i have read also over the pages that there has been a couple of years with the wifi problem which ALSO my TV has it.
come on SONY
GET SERIOUS.
where are your software developers?
p.s
a solution for the wifi problem is to deactivate the password for the wifi and restrict to 1-2-3 users (depending the need) access to the wifi data. sometimes it freezes for 2 seconds but in general terms , it does the job.
SONY, GET SERIOUS A GIVE PROPER UPDATE FIRMWARE FOR EVERYBODY
