Logging into YouTube failure.
bearjosh
Having owned my Bravia for over one year I have never succeeded in logging into my YouTube account.
Firstly can a forum member please tell me exactly what should go into the User ID box and the Pin Code box.
Please give examples. I do not know what a pin code is meant to mean.
Previous answers to this problem have not been explained clearly enough for me to have any success.
I have even set up a new account for this purpose but the pin code box remains an enigma.
I know there must be many hundreds of people with the same problem but Sony still insist on calling one of the boxes PIN CODE!!!
bearjosh
Thanks for your help
Will try
Message was edited by: bearjosh
buseng
I had this trouble. After trying all suggestions what I found to work is to use my old original Youtube username & password before it became part of Google & linking it to my Google account & trying to use the new Google login details. Putting the original password in the pin code box should work.
Message was edited by: buseng
bearjosh
Will try
