Love film and Sony essential problem
KRaccount
Hi,  I want to change the Love Film account that is registered to my Sony Bravia TV. I have tried to log on to Sony Essentials by my Sony user name and password do not allow me to access the site. I have requested a new password but do not get an email sent with a new password. When I try to create a new account, I am unable to to get a registration code as my tv is already registered.
Please help!
13 REPLIES 13
Catmambo
Hi
The Essentials username and password is unique and different to this website - are you using the right one?
I checked and sent a request for a password reset and the link came through to my inbox instantly, so don't think there is any problem there. You will need to login and de-activate your particulare device however, so maybe try the password reset again - just check you are enterting your email address correctly.
firejeff
:slight_frown: I have the same problem.  why do you need to log into so many different accounts, I have logged into 'My Sony', then tried 'ESSENTIALS' then logged into this 'forum'.  Surely logging in once you would expect to be able to access everything you need.  I have tried to register ESSENTIALS but I too have a message on my tv which says I have already registered my product, so how are we able to get My Sony and ESSENTIALS to talk to each other.  I just want to watch LoveFilm on my TV.  Sort it out SONY because I have had enough!!
nayan007
Infact I too have the same problem. Please help http://imagicon.info/cat/12-13/vmware_happy.gif
Thanks,
Catmambo
Hi Firejeff - I do agree, however Esstentials and My Sony are two different platforms and so won't talk to each other. Essentials is being shifted to PSN/SEN so it will have a common login very shortly.
In the meantime, your product is already resgistered, so you need to log back into Essentials and deactivate it and simply then pair your account up with whatever new devive you are looking to pair with. If you can't log back in, just request a password refresh and you'll get an email within a couple of seconds explaining how to go about this. The whole process should only take a couple of minutes.
This should fix thins for you also Nayan007
firejeff
Hi Catmambo
Thank you for your reply
I cannot log into ESSENTIALS as I haven't yet created an account
I cannot create an account because I can't get a Registration Code
I cannot get a Registration Code because my TV says its already registered
I can't request a password as I don't have an email registered with ESSENTIALS
As you can see, i'm in a bit of a loop here with now where to go!
Best regards
firejeff
firejeff
Hi Catmambo
My device is brand new which I bought from a shop
You do need a code for ESSENTIALS, It will not allow me to register without it
Many thanks
firejeff
Catmambo
If the device is already registered because it was second hand or something, then the original owner needs to deactivate. If that's not possible then you need to call the call centre to start that process.
Catmambo
My bad - yes you are right, it is needed to register..
In any event, its bizarre your device is already registered. If its a recent purchase, I'd get in touch with the shop as devices should be unregistered out of the box as one would expect..
The device will give you a code on the screen if you try and play a movie on Lovefilm and you aren't already registered, but I'm assuming that you;ve typed in this code and its told you the device is already active?
firejeff
Hi Catmambo
I can remember having a code when I registered my products with 'My Sony'
I needed to enter this code to have my Blueray player, amp and TV to talk together
Now that I have done this, I can't register it with ESSENTIALS
Not sure why I have to register the same information with the same company (Sony) twice
When I look in 'Network' and 'Activate Enhanced Features' on my TV it tells me that my 'Device is registered'
If I have already registered with 'My Sony' why register again with ESSENTIALS?
I just want to use 'Lovefilm' on my TV
Regards
firejeff
