Missing Network Applications/Icons
Good Afternoon all
You may be aware that when you go into your Applications on your TV, that various "regional" based icons are missing (eg, BBC iPlayer, Demand5, etc).  The following is Sonys statement:
“We are aware that network services of some products are currently unavailable.
Details are under investigation. As soon as we get the detail, we will post it on our Support Website.
This is applicable to 2010, 2011, 2012, 2013 BRAVIA TV's.”
This thread will be updated with more information when it becomes available.
Thank you all for your patience.
Hi All
Just got back from being away for a couple of days, I can confirm that these network (SEN) applications are back on my TV.
Hi All
athon640
HI,  THE WIDGET FACEBOOK AND BELLO DOESN'T WORK ON  TV SONY W828. THE PROBLEM PERSIST IN ITALY.CORRECT PLEASE.
Hi there
Please see another thread :
http://community.sony.co.uk/t5/televisions/current-outages-oct-14-sen-applications/td-p/1803571
Also, if the problem is in Italy, please use the italian forums:
http://community.sony.it/t5/it/ct-p/it
Also for future reference on internet ettiquette, please do not use all capital letters in your posts (its considered shouting).
Thank you.
