my bravia wont connect to the internet?
profile.country.en_IE.title
evan121212
my bravia wont connect to the internet? im using a cable from router to tv.
11 REPLIES 11
Catmambo
Have you told the TV how you are connecting via settings?
http://www.sony.co.uk/article/id/1237479247084
thanks
evan121212
yes i did, i even reset the tv to factory setting, reset the router, still internet access fail with error code 2200.
Connection Results
cable connection: ok
local access: ok
internet access: failed
i went to this website:
http://sonycic.custhelp.com/app/answers/detail/a_id/1042/kw/uwa-br*/related/1
thanks.
evan121212
still no internet connection....pls dnt give up on me. thanks
Pcadjb
Hello Evan,
                   At which stage of the connection does it fail
1. Step 1 - OK
2. Step 2 - OK and settings same as PC
3. Step 2a - contact sony support - do not continue further contact 0845 6000124 0 or 0844 8466 555
4. Step 2b - setings do not match
5. Step 3 - Reset product
6. Step 4 - Reset router
Pcadjb
evan121212
hi Pcadjb,
it fails when after doin all the set up and you try to refresh the connection. i did reset both router and factory setting of the tv, still connection fail (error code 2200). im using a cable not wifi.
the IP address from pc does not match with the tv IP last 1 digit but the rest are the same except the last one.
evan
Pcadjb
Hello understood,
                              IP address looks OK, 1 digit different is OK.
Just 1 additional question which make/type of router are you using and who is the ISP (Internet service provider).
This may help understand the issue more.
evan121212
Router: Belkin N1
ISP: Digiweb, ireland
thanks.
evan
Catmambo
Have heard a few stories of Belkin incompatibility. Any chance to try it round a friends house to see if its the router?
thanks
evan121212
ok ill try, many thanks.
evan
