My remote has suddenly stopped showing the programme guide. When I press the button there is no response but all other buttons work as normal. Any ideas what I can do ?
kevinsheerin
Bravia55HX
Hi again,
ok, if you have any warranty left take it up with your dealer for a replacement remote or see if you can borrow one to test, it may be that the guide button is stuck somehow.
failing the above, the remote has a model number on it you could have a look on e bay for one or try the link below.
http://www.4ourhouse.co.uk/cgi-bin/home.pl
Bravia55HX
thats a little odd however can you try the following before you dismiss this as faulty, remove the batteries and re insert them, better still replace with fresh ones and try again.
kevinsheerin
Thanks. I have tried replacing the batteries. Same result: every thing else works but not the programme guide. As you say, it's a little odd.
Bravia55HX
Hi again,
