NetFlix Lip Sync
Denis-62
NetFlix Lip Sync
I'm experiencing really bad lip sync issues with Netflix - even when using the TV's own speakers.  I can't find any AV Sync adjustment on the TV settings menus either.  Is there a fix for this?
4 REPLIES 4
Sean_Mc
Moderator
Hi Denis,
Can you let me know which model of TV you are using?
Thanks,
Sean Mc
Denis-62
Sorry - I should have said in my original post - it's the KD49xe7002
Drewde
Administrator
Hi Denis,
Have you always had this issue or is it something that has just started happening?
Thanks,
Drew
Denis-62
We've only just signed up to Netflix and the lip sync issue was noticeable straight away.  We bought the TV last November and haven't had any problems with Sky, DVDs etc.
Denis
