No Iplayers on KDL-46HX903
keplyer
Hi I seem to have lost the iplayers on my KDL-46HX903 They used to be there. I have the system updates switched on and when I try to refresh internet content it keeps on showing an error and telling me if this persists to call sony<5006> has anyone gat a clue whats wrong.
Ken
Bravia55HX
5 REPLIES 5
Catmambo
Sounds like its not connecting to the Internet properly. Have you tried rebooting your router and also making sure you have the latest firmware on the router also. Also just double check you have the latests firmware manually. You said its set to auto update, but it may not have updated for some reason..
How is the TV connected to the web?
keplyer
I am using a wireless connection  and have got five bar signal strength.
keplyer
Hi I have just sorted my problem out I reset the TV to factory settings and started from scratch and have got all the missing stuff back.
Bravia55HX
Catmambo
Bingo - usually does the trick :slight_smile:
