Parameters not kept
profile.country.fr_FR.title
lilijody
Parameters not kept
I have just bought a Sony KDL 65HX920 but I have a problem with parameters. When I change it as I want, it is not kept. It comes back automatically to the ones predifined. How do I keep the parameters that I want? Thanks for your help.
Catmambo
Hi
Thats odd. Are you running the latest firmware? CAn either update via USb stick or by connecting the TV to the Internet and accessing the menu settings.
http://www.sony.co.uk/support/en/product/KDL-65HX923/downloads/AZ2EUA_4107
