Photo playback KDL-46EX503 only showing thumbnails
stranexuk
I have my TV wired to my network and am able to access my picture library on both my WinPC and my NAS. However, when I try to view jpgs via the netwrok they always appear as smaller res pictures on the screen (640x426) although when I view the EXACT same photo via USB it displays correctly at full screen size?
I have read of issues regarding saving jpgs at lower quality but i my case the jpeg is EXACTLY the same, just copied from my photo library to the USB stick. USB diplays fine, anything veiwed over the network (even when saved at lowest quality possible) displays the smaller "thumbnail"?
Hi there
I would have expected your question to be the other way around, as in thumbnail for USB (as there is a setting for that).  Are you able to post a photo of how it is displayed - as im a little unsure at the moment?
Also are you using a DLNA server - are there any setting on that, that may effect viewing?
