Photo slideshow on KDL-40W705C
Gruppy63
I have attempted to view photos via a USB on my KDL-40W705C TV. I have managed to get to the Album page where several options are available. I have chosen the browsing view showing the USB and internet connections. I can view the photos manually one at a time, but it seems there is no way to view a folder of photos as a slideshow. Any ideas?
There is also a calender view which seems to only display a default sony view.
Hi there
I do not thing the photo slideshow is supported any longer.  I have compared the manual of your model TV to a preview years model, and there is no mention of photo slideshow in your manual at all - whereas it is in another previous years manual.
You should be able to use the arrow or OK button to move to the next picture I believe.
Gruppy63
Hi, thanks for your response. You are correct that I can only use the arrow keys on my remote to view the USB photos. But I have tried enrolling in "PlayMemories Online", and after a bit of effort I can run a slideshow via the online site. The only issue is there is no control of the transition speed, and possible the download internet usage.
Regards
Grumpy63
Hi there
The only other thing I can suggest is if you have a Android based smartphone or tablet, put the photos on it and use the 'Screen Mirroring' function.
Instructions:
http://pdf.crse.com/manuals/14XM070111/EN/wfdisplay_wfintegrated.html
And then use an app such as:
https://play.google.com/store/apps/details?id=com.scoompa.slideshow&hl=en_GB
