Program List Edit
profile.country.HU.title
krolkun
Program List Edit
I have a KDL-W805A tv.You're going to see the catwalk on the pendulum, the pc I see is also in sdb.xml format, I try to open it with the hook structure but you can not see it do anything.KDL-43W807C tv works with the channel building program. Someone should have some idea of help. Thank you in advance. The translation google did apologize you can not speak English. Thank you Károly Kun
Win_88
Specialist
Hi Krolkun,
I put that into google translate so I'm not sure if what I understood is accurate.
If the xml file that is exported by the W805A can't be opened by the application, I'd recommend the following:
1-Make sure the TV is running the latest firmware.
2-Try tuning the channels without the antenna first, then tune again with antenna connected before trying to export the channel list again.
3-If the issue remains, try resetting the TV to factory settings and try again.
Hope this helps,
Win_88
4 REPLIES 4
Pascale_F
Moderator
Hi Károly,
I'll just try to find some answers for you about this. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Win_88
Specialist
Hi krolkun,
You can take a look on the following link to make sure you are following the correct process to load and edit the channel list for your W805A: https://www.sony.co.uk/electronics/support/articles/00198697
Hope this helps,
Win_88
krolkun
KDL-42W805A letöltöttem az sdb.xml fajlt de a program nem nyitja meg.KDL-43W807C-rol letöltés ugyan ugy sdb.xml fajl azt kezeli a program.A 805C rol letöltött fájlal nemtud mit kezdeni az editor.Köszi a választ előre is.Üdv Kun Károly.
Win_88
Specialist
Hi Krolkun,
Hope this helps,
Win_88
