RDF-ED001W remote not working
Mgraham47
I have a sony bravia KDL-40EX1 tv and the remote stopped working properly, skipping channels and volume ect, every time a button is pressed the EXT button flashes, batteries have been changed, still not working so purchased a new remote, this one doesn't work at all and the EXT button flashes, any advixe would be really appreciated!
profile.country.de_DE.title
chrismol
I'm having the same incident!
Also bought a new remote, and now detecting the same errors. Buttons are not working, EXT is flashing a button is pressed. What is the issue here?
Thalamus.
Champion
Hi Mgraham47,
welcome to Questions & Answers..
My inital suggestion would be that the batteries in the remote need to be replaced but as you have tried that & purchased a new remote that is obviously not a solution in your case..
I had a look at the user manual & might be a long shot but have you tried pressing the Ext button to see if that solves the problem..:smileyconfused:
Failing that have you got any other devices connected to your bravia, if so does removing them allow the remote to work correctly..:smileyconfused:
