Record series possible?
RoelofV
I would like to set a repeating timer, to record series, e.g. daily or weekly. The Bravia doesn't seem to support it. The manual states 'depending on local situation'. Since there is a connection to the Guide I can see some logic in this statement. But there also is a possibility to manually set a timer. There I would expect an option to select a repeating record timer.
Does anybody know if there is a possibility for such a repeating timer? And if not, if there are any plans to make this possible?
0 REPLIES 0
