Registering a USB with files etc on it
winker71
Want to register my USB, it says that hdd data will be deleted during this process. Does that mean that it will delete all data on the USB device when registration process is happening. I have a lot if work stuff, photos and films.
Yes, all files will be lost.  You will need a dedicated USB drive/HDD in order to register it to the TV.
winker71
Thanks, lucky I asked or I would have lost everything.
Hi there
On a side note, If they are important irreplaceable files - I would strongly recommend them being backed up.  :slight_smile:
