Remote RM-ADP077 Sky box code?
tenfxx
Hi, I have a AV remote RM ADP077, can I use this to control my shy HD box? I have tried codes in the instruction and forums but nothing. My box isn't showing. Sky box is made by SKY model no R005.053.70.11P version no 4f3154. Thanks.
Bravia55HX
i do not believe this remote can accept codes to use other equipment as its not a learning remote or universal one.
tenfxx
Thanks for the reply.
profile.country.ru_KZ.title
Mendalson
The RM-ADP077 remote can control the sky decoders acording to my new Sony home theatre system.
Instructions from on screen:-
  1. hold STB and press pop up/menu for one second. STB should flash slowly.
  2. key in code 8295 or 8241 (sky codes)
  3. Press ENTER
  4. Try the remote, if no success. Go to step one and the other code.
