Removing redundant media servers
confused.com
Can anyone tell me how to get rid of media servers from the display on my Sony Bravia.  I just downloaded Homestream, so don't need the previously tested ones (although I may get Mezzmo back if Homestream doesn't pan out).  I have deleted the software on my PC but there doesn't seem to be any way of removing them from the TV.
buseng
Yes, in order.
Home
Settings
Network
Home Network Setup
Server Display Settings
Highlight Homestream
Options
Highlight/Select Delete
Highlight/Select Yes
That should be it.
buseng
Yes, in order.
Home
Settings
Network
Home Network Setup
Options
That should be it.
