Screen problem Bravia KDL 32D3000
The right hand third of the screen of my Bravia has developed vertical lines and discolouration. Have checked aerial and connections and all are fine. Any suggestions? TV is 6 years old. Thanks!
Tags (1)
Hello there
It appears that your TV has developed a hardware fault.  The first port of call would be to contact an authorised Sony Repair Centre to get this fault diagnosed and repaired - see link below
http://www.sony.co.uk/support/en/repair/asc
However doing a quick search around, it appears you are not the only one that has this fault (links below).  Unfortunately I dont have the time at the moment to go though all the theads, but it seems that the Timing Control Board needs replacing.
http://community.sony.co.uk/t5/Televisions/KDL-32D3000-multiline-screen-fault/td-p/186218
http://www.avforums.com/forums/lcd-led-lcd-tvs/1529164-sony-bravia-kdl-32d3000-purple-vertical-line-...
