Sony Bravia 32/s3000
pdgalaway
Can anyone help my tv for the past few days has had the channel number and when sky is on it comes up with the channel number and 1080i/50 i have gone through the settings loads of time.
Does anyone have any sudjestions. sorry for any spelling as i have brain injuries as a british soldier
thanks everyone
Hi there
Try pressing the i+ button on the remote control.  You may need to press it a couple of times as it cycles through other options.  I have circled the button in red on the picture below.
4 REPLIES 4
Hi there
pdgalaway
Thats great thank you for future ref if i cant find the remote to sort it is there away to do it on the main tv
I dont think so to be honest.  However, if you cant find your remote - you cant accidently press the i+ button to enable it, so...  (I dont believe it comes on automatically anyhow)
Im glad its worked anyhow.
pdgalaway
once again thank you
