Sony Bravia KD55XE7003
soma14
I am trying to put apps on my Sony Bravia KD55XE7003 can somebody help please??
rooobb
Your TV is not an Android one, you have only the preinstalled apps from Sony and the ones available in the Opera Store. Nothing else.
Miles_Gonzalez
Do you want to install apps to watch some special movies? well, I got the same model like you. I found it difficult to install movie apps on this model and iTunes is not able to be installed? I personally try another solution to transfer the movies through an USB flash drive to play iTunes movies on sony bravia TV. It turns out to be the best solution I found currently. Congratulations. Cheers!
