Sony Bravia XD55XF9005B / image takings too long upon turning TV ON
Fran_GV
Hi.
As I turn on the TV with the reomote control (that also controls the Virgin TV box), it takes more than ca. 4 min for the image to appear. The sound turns ON normally and the remote control works to change channels, etc. I guess this is by no means normal... Thank you!!
Sean_Mc
Moderator
Hi  Fran,
I would suggest trying a reset of your TV which should resolve this issue for you. You can find more details on how to perform a reset here.
Let me know how you get on.
Best wishes,
Sean Mc
