SONY KD-49XE7077SAEP shows me 25Hz rate on TV option, poor image quality and disappointment.
profile.country.GR.title
Rigas_GR
I buy this SONY KD-49XE7077SAEP, run the TV tuner setup guide and the image quality is not that want.
OK the Greek TV singal is HD channels is 1080i 50Hz.
The option I get when press the Info button, is the correct resolution to each channel, but gives me 25Hz.
Also very big pixel in image quality.
Final the Greek SONY website shows a different remote control , with Netflix and Youtube keys.
The remote control in my TV is like a cheap 30$ tv tuner , Is the 3rd SONY i buy in my life but so simple remote control.......
Disappointment because already buy 2 PS Pro and want something better in users experience.
IamNic
Hi @Rigas_GR,
do you watch TV via the inbuild tuner, or do you use a receiver?
Also if you use an external receiver, how do you have it connected (HDMI, Composite Video, Scart)?
- Nic
Rigas_GR
I use the built in TV-Tuner with the classic antenna on the roof of the building.
No need HDMI to see TV programm.
IamNic
Hi @Rigas_GR,
Hz has nothing to do with the frames displayed per second.
Also 1080i ("i"=interlaced) gives you 50 half frames which result in one deinterlaced feed with 25 frames.
So I don't think anything is wrong with it.
The only thing I wonder is, why you experience "artifacts" (big pixels).
- Nic
