Sony KD-55X9005A Wall Mounting + VESA
whatleydude
Hi everyone,
I'm looking at purchasing the above UHD/4K television but can't find any information about how to wall mount it and/or what the VESA measurements are for this TV.
I've currently got this wall mount - http://www.amazon.co.uk/Designer-Habitat-Wall-Tilt-Bracket/dp/B003U46SWC - installed on the wall, and the real question is: will the KD-55X9005A fit onto that?
Any and all help would be most appreciated,
Thanks!
James
Hi there
The following PDF document contains the information you wish to know.
http://community.sony.com/sony/attachments/sony/manuals/89/3/XBR55X900series_cutsheet.pdf
Hi there
whatleydude
YES!
Thank you! :grin:
