Sony KDL-22EX320 EPG CHANNELS MISSING
SteveSuffolk
Good morning, I hope someone here can help me. I have the above TV connected to an external, boosted Freeview aerial. The picture quality is perfect, yet the EPG information is very hit or miss. Sometimes the BBC schedule is missing, sometimes the ITV schedule is missing, or even both at the same time. Does anyone here know how I might fix this problem? Steve
Message was edited by: SteveSuffolk
Tags (2)
Bawmer
OK sorted it.
It is caused by duplicate channels from alternative transmitter which are put in the 800's on scanning.
The channels need to be cleared by doing a scan from auto set-up with the aerial out. A manual tune should then be carried out using the channel no's found for your postcode on the digital uk website.
Bawmer
New Bravia setup fine but getting the same problems as above. Anyone found a fix?
Bawmer
OK sorted it.
