Sony KDL-32W653A mount dimensions
ujraut
I've been trying to find the actual dimensions of the mount where TV stands, particularly the width described with red in the attached picture, so far have not found this dimension. Hope somebody could help providing this info.
Hi there
The only information I can find is this:
You might be able to extrapolate the data and get somewhere close.  Alternatively, you might want to go down to your nearest Sony store or retailer with a tape measure.
Hi there
