SONY Media Remote KDLNX710
profile.country.el_GR.title
algeFF
Dear Sony,
I intend to buy a sony KDLNX710 tv which I found in a really good price.
The SONY Media Remote supports it with the latest firmware update or not?
If not, is there any other program in the AppStore that supports this TV model?
And my last question is, because I am in iOS developer where can I find the protocols that this model uses so I can make it myself?
Thanks in advance.
*I have read that the Media Remote Supports from the KDL720Model and after, but as far as I could search these two models work under the same protocols.
drhowells
HI, looking at the software specs, this TV does appear to be supported. I think I have seen somewhere else on the forum that someone tried it and it didn't work as well. There will be no other program to use. I very much doubt Sony are going to give you technical information about their products to make your own software, sorry.
drhowells
