sound bar for kdl40cx523
ancousins
Hi All
        Could you recommend a good but reasonably priced sound bar for a kdl40cx523, or will the bar/stand
for the ex fit?
Bravia55HX
this is the one on the Sony site designed for this tv, hope this helps.
http://www.sony.co.uk/product/tpa-tv-speakers-and-speaker-grilles/sa-40se1
Bravia55HX
