sound lag when i switch to sound bar ht-ct 290
profile.country.IE.title
johnl18
Has anyone got info on how this is happening.
TV is a KD-49XE8396
4 REPLIES 4
EdwinaU
Moderator
Hi John,
Welcome to the community.
There is an audio system settings guide for your TV here that may help with this.
Best wishes,
Ed
johnl18
Thanks Ed
I will try this when i get home.
John
johnl18
Hi Ed
Still no joy with sound bar. I have tried every which way to connect sound bar to TV, HDMI, optical cable
together on there own. The issue is still there very frustrating. There seems to be a lot of reviews
saying they have lip sync problems with the same model. I wonder if it is compatible with my TV.
John
Almou_10
Specialist
Hi johnl18,
There are two different types of sound lag or lip-sync. The first is when you watch any content and the lag starts from the first second till the end, the second, which is called drifting, is where the movie or content starts normally at the beginning then the lag starts to happen gradually.
I'd suggest removing the soundbar from the mains for a couple of minutes then try and check which type is it first so that I can tell you the best solution.
Cheers,
Almou_10
