Subtitles are not available on Sony Bravia Netflix App
onahshon
Hi
I own a Sony Bravia TV and installed a Netflix app.
I have a problem with the subtitles: In all other Netflix apps I use (on iphone, android, web, Xbox) I can easly select Hebrew subtitles for all shows.
In my Sony Bravia Netflix app I can only add English and Polish subs...
Can this be fixed please?
Thanks!
6 REPLIES 6
Sean_Mc
Moderator
Hi there,
Can you let me know the full model number of your TV?
Best wishes,
Sean Mc
onahshon
KDL-50W656A
thanks!
onahshon
Hi
my model is KDL-50W656A
Please advise
Sean_Mc
Moderator
Hi again,
Thanks for the information.
If the subtitles are in the wrong language, it typically points to an issue with the settings on your profile or device.  I would therefore recommend going to the Account section of the Netflix website for further help.
Best wishes,
Sean Mc
onahshon
It's not a Netflix profile issue. My profile is set for hebrew and is working well in all other Netflix apps running on any type of device (web, iphone, andriod, XBOX)
this is a problem wich only occurs on my Sony Bravia Netflix app:
Hebrew titles are simply not avilable - I can get  only Polish and English. I know that many other languages are availbale on Netflix servers because I see them my other devices.
Can you please check and fix the Sony Bravia Netflix so that ALL languages will be available - including hebrew?
Sean_Mc
Moderator
I would recommend getting in touch with the support team here for further assistance.
Best wishes,
Sean Mc
